rdnecks »
https://forums.nicoclub.com/rdnecks-u12384.html
Fri Jan 09, 2004 11:45 pm
ok that worked grate I fixed the vaccum leaks. It is running good i found out that the auto trans did not work so i pulled it. And cracked the case on the manual trans it was locked up the only thing i found in it it looked like a washer cut in 1/2 ian it was magnatised it was stuck in the yock. Ya that would lock it up. I looked for a place for this in the case and did not fined a place for it . Everthing looks good it this trans. Is there a place for this 1/2 moon thing in the trans or did some one drop it in there
thank you for your time RDNECKS
