88 Nissan 300sx (z31) swap
S14DriftinThruFL
Car: tuning imports
Though i have very few posts ever made, i am a constant reader of the forums, and before i ask this question, i will state that yes i have used the red search button and tried just about every combination in hope that i can find the answer. Does anyone know if the rb20det will swap into the 86-89 Nissan 300zx. If so, where can i get some information about. are there any companies who have successfully done it, or kits, or ANYTHING. Thanx
McAdam
Car: I like cars and my motorcycle. boats are fun too
Actually, do a search on google for a 200ZR. fUnny you should mention it as this was an actual factory option for the 300zx in japan. http://saboten.sakura.ne.jp/~r...3.htm check out that link. should be of some use to you!
McAdam
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Yes... this is a sick car... and should be a very direct swap. If you would like I could talk to my contacts about getting a RB20DET Z31 front clip. I'm planning this swap sometime after I do another rb20 S13 swap.
S14DriftinThruFL
Car: tuning imports
thank you both very much, your information has been very helpful. Also, if i can find a front clip from the actual z31, it should have everything i need for the install correct? or, can i just use the r32 clip?
McAdam
I beleive you'll need the Z31 clip as the front crossmembers between the 300zx and skyline do not interchange. and teh eninge mounts are welded to the front crossmember. but, the skyline engine is the better of the two from the factory. so, kind ofa tough call. now, if you could find someone to custom make some mounts for you, get the skyline clip!
McAdam
masamunex03
Car: nor is this
"200ZR engine mounts oilpan, pickup tube and sump" a Zed once said
rbsileighty
Shoot me an email at [email protected] on monday and I will try and get up with some of my connections on getting just the x-member.
I agree... If i'm not mistaken the Z31's rb was a red top RB20... which are kind of crappy. Definitely want a silver top...
rbsileighty
OK, here you go. I really really hate bringing up old, dead threads but this is worth it.
http://cgi.ebay.com/ebaymotors...73018
Here is your x-member!
I would bid on it to help out, but I'm heading out in about an hour. Only has 4hrs left.
