DanDare »
https://forums.nicoclub.com/dandare-u27459.html
Sat Apr 02, 2005 11:49 am
Really frustrated here......
1988 Maxima, 90K miles
Developed hesitation during idle and acceleration about a year ago. So I did the basic stuff like:
Fuel pump replaced last yearFuel filter replaced last yearNew plugs / wires recentlyReplaced majority of vacuum hosesNew throttle position sensor
Problem got worse about a month ago. As I tinkered with it, I noticed (not sure how important this is) that when I removed the top vacuum hose of the Air Injection Valve control solenoid, that it ran extremely well, so I just left it off.
Well, about a week later, the problem returned with a heavy fuel smell and eventually wouldn't start (sounded like it wanted to, but wouldn't).
I replaced the coil and the PCV valve, still no luck.
Towed it to a local auto repair shop. They said it was dumping too much fuel and that they replaced the plugs and the oil (said there was fuel in the oil). Then they said it needed a new coolant temp sensor, so they replaced that. They did find a crack around the end of the air intake hose, I can find one of those at a junkyard (would that cause all of this though?).
Well, after that, they got it started, but it still ran like crap and told me it was the Mass Airflow Sensor. They wanted too much for the part / labor, so I was able to drive it home and replaced the MAF myself. I cranked her up and it ran well for about 5 minutes, but the same old problem has returned. The ECU is showing "normal operating" if you can believe that. What could it be????
