88 Maxima 3.0 V6 5spd gas leak
retrorich77
Car: 88 Nissan Maxima
i was gifted the car from a friend.there is some sort of gas leak on the right rear it seems,when i put a new battery in,to try and start it,once the pump primed,it started dripping gas out onto the ground.didnt really get a good look at it.the old owner said it was a rubber fuel line.is their any sort of repair manual,or something i could print out,so i know where the rubber fuel lines are on this car?is this a common problem?help is always greatly appreciated.ThanksRichy
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
If you climb under the car, there will be two lines running paralell on the drivers side (I think), that run from the tank to the engine bay. Put on eye protection, and follow the lines. If you can not find the leak, have someone prime the pump while you are under there. Hopefully you will see it leak.
