s0m3th1ngAZ »
https://forums.nicoclub.com/s0m3th1ngaz-u27191.html
Sun Oct 30, 2005 10:55 am
alrighty ive had moby d!ck taken to 2 different mechanics (nissan dealer and my family's tech) and neither of them have been able to fix the problem.
basically cold starts are a *****. it takes several cranks (on average) to get the pistons firing and it happens gradually. once it does fire it may or may not hold rpm and stay in warm-up mode. sometimes it pegs at 2 grand and does the normal thing and fall back to around 800rpm, others its fluctuates like a pendulum. cold weather doesnt seem to affect it, in fact it's easier to start in the morning than when i come home after class/work where its been sitting in the sun. once everything is gravy and i put the engine under load, i can hear piston slap (or some metal parts banging up against other metal parts, but thats the way i would describe it) this goes away in about a minute.now, the techs that have worked on it gave me conflicting opinions. the nistechs said the afm was malfunctioning, however the other one said it was in perfect order( even tried a new afm and it didnt have an effect) after $300 worth of diagnostics, my family tech ruled out several things. he replaced the air auxiliary control valve/switch, secondary injectors, the idle up sensor/switch, fixed a wiring problem involving home depot spl, a vacuum leak, and gave it an engine treatment. none of this to any avail. it still does the same thing every time i let it sit for a couple hours. however it does run allot nicer:P
oh, it runs perfectly after being warmed up.
so any other ideas you guys can throw at me? im tired of spending money and not having **** fixed.
