87.Z31 side rear window trim removal?
A home for 1983–1989 300ZX owners!
nycdon
Car: 300zx/2+2
Is there a diagram and a special tool to remove the window trim on the glass? its the rear glass just over the rear wheel well. I have some rust there that I need to treat.
G-E
Car: 1. 1987 300zx Turbo-swap, SF interior, koni rallisport springs/struts, msa swaybars
2. 1997 Sebring coupe
3. 1987 300zx 2+2 becoming a caged racecar with RB swap...
No special tools, two nuts, some clips, maybe heat...
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
The only trick is that you have to basically dismantle the car. The interior quarter trim has to come out to get at the nuts that hold it on, and if memory serves the trim is bonded to the glass which is also bonded in so you have to push it out slowly with aid of heat if it's cold at the time. Also the interior quarter trim requires the carpet. and pad form the parcel shelf be removed, then the shelf, and the rear finisher and the rear roof trim IIRC. Time consuming but not difficult.
Return to “300ZX (Z31) Forum”
