DeathBy240SX »
https://forums.nicoclub.com/deathby240sx-u1553.html
Wed Sep 21, 2005 11:31 am
I just bought an 1987 Sentra with the carbed E16I engine. When I test drove it, I boosted it and it started and ran fine. I went to pick it up and I boosted it, ran OK but the idle was surging a bit and then fell to around 500 rpms. I kept my foot on the gas a bit, as I thought it might just be the battery losing power so I tried to keep the idle higher.
I got it to a gas station put $20 in and put in a half litre of oil as it was a bit low. I didnt turn it off as I didnt want to have to boost it again. Just as I was about to leave the car died.
We tried for about an hour to get it started again, push starting it, putting gas in the carb, and boosting it. It caught a few times but it idled very high then died out after a few seconds.
I went back the next day and put a new battery in. It will turn over now but wont catch at all. I'm assuming it has no spark as we put gas in the carb again and it changed nothing.
So where should I start? I have already replaced the spark plugs as they needed to be anyway.
Should I got a new distrubutor and plug wires? Or does it sound more like a timing problem?
The timing belt was apparantly replaced last year and the car was parked a short time later. The seller maintains it is because of stale gas, but I know that isnt the case.
I only paid $300 for the car, so I am not going to take it in to a dealer or anything.
Another question, do repair manuals usually include the procedure to pull the codes off the ECU? I havent been able to find any info about that online.
Thanks!
