87 Pathfinder need some help
Ryman
Car: 2001 Infiniti QX4
K so my friend has an 87 pathfinder and wants to change his speakers out and wants to know how to take off the panels holding in his 6x9s in the rear if anyone knows or has info any would be helpful
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
Ryman wrote:K so my friend has an 87 pathfinder and wants to change his speakers out and wants to know how to take off the panels holding in his 6x9s in the rear if anyone knows or has info any would be helpful
should be screws along hte panel.... look around should be near the door handle, from there you gotta panel pop it off as its held on by clips. go slowly if you find its not budging stop and locate the screw holding it.
Ryman
yeah see that's the problem.... it's not a door it's a two door and the speakers are mounted in the middle of nowhere and i don't know what to do i'll try to get some pics if can
Innovazn
Ryman wrote:yeah see that's the problem.... it's not a door it's a two door and the speakers are mounted in the middle of nowhere and i don't know what to do i'll try to get some pics if can
ohhhhh its the two door one.... hmmm ill look into it
philipa_240sx
IIRC, there are a couple of screws... behind the flip out ashtray and maybe beside the rear seat... near the floor. The rest of the panel is held in place with spring clips... simply pry.
I miss my '87.... it was a gas guzzler, but fun while I had it.
scaramoche
Car: 1989 Nissan Pathfinder
if it's the 2door, then you have to remove the side panels. they are held in with nylon pop posts(not sure what they are called.
basically you need with a large flathead screwdriver, slowely pop panel off. Here is the problem, some, if not all of the nylon buttons will break, I would hit the auto store up and get some replacements(only a few dollars for a dozen or so).
It's not difficult, just a bit time consuming
scaramoche
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
philipa_240sx wrote: I miss my '86.5.... it was a gas guzzler, but fun while I had it:
'86.5??? The first PFs were '87 models and came out about about October '86, which would be '87 model year.
I bought my '87 12/31/1986.
Ryman
k thanks everybody it looked pretty easy to pry but i didn't want to pry everything and break stuff... i'll give it a try and let you guys know
philipa_240sx
Chuck Tribolet wrote:'86.5??? The first PFs were '87 models and came out about about October '86, which would be '87 model year. I bought my '87 12/31/1986.
I had serial #000749... one of the very early ones off the assembly line. :biggrin:
Ah, I think I know where the confusion is... The Hardbody/truck was available as an '86.5 model year. My mistake.
Wow, I sold my '87 pathy 10 years ago already. Boy does time fly...
