that's interesting, I didn't think 93 octane existed in California... there's not a 93 octane gas station in San Diego!BatmansDreamCar03 wrote:I use the highest at chevron (i think its 93) and i have a 2.5kind of expensive and i hear it burns faster but its worth it to keep my engine as clean as possible
i also use 91 sometimes if i am really low on money
You are are very misguided young man and tossing 50 cent pieces out the window of your car for no reason what so ever........BatmansDreamCar03 wrote:I use the highest at chevron (i think its 93) and i have a 2.5kind of expensive and i hear it burns faster but its worth it to keep my engine as clean as possible
quite unnecessary. your car is tuned for 91 and will receive 0 benefit from using 93 octane.skiski329 wrote:i was told 91 or higher. i use 93, you get what you pay for.
.Actually, The higher the octane, the more efficient your engine will be. 91 and above octane will burn faster and cleaner during detonation (When the piston is in it's highest point) unlike 87 which will burn slower and be wasted when the exhaust valve is opened. Using 91 and higher on a 4 banger IS a waste as the compression ratio does not warrant it UNLESS you have turbo or supercharged.BatmansDreamCar03 wrote:I use the highest at chevron (i think its 93) and i have a 2.5kind of expensive and i hear it burns faster but its worth it to keep my engine as clean as possible
1) Octane burns slower and has a higher flashpoint than heptane. The "octane rating" posted on gas pumps is a reflection of the fuel's resistance to ignition based on a sliding scale of a mixture heptane:octane where 0 = 100% heptane/0% octane, and 100 = 0% heptane/100% octane . Note: it is possible to have higher than 100 octane rating (implying >100% octane) by using substances that have greater resistance to ignition than octane.dangeris wrote:.Actually, The higher the octane, the more efficient your engine will be. 91 and above octane will burn faster and cleaner during detonation (When the piston is in it's highest point) unlike 87 which will burn slower and be wasted when the exhaust valve is opened. Using 91 and higher on a 4 banger IS a waste as the compression ratio does not warrant it UNLESS you have turbo or supercharged.
With the 2.5....You should notice no difference, Good chance it is in your head. Some cars tuned for regular actually lose performance with Premiumstsxcrle wrote:I was using 87 until someone suggested using 91 or higher for better gas mileage. No better gas mileage but there IS a difference in performance. Temps have been about the same, just went to 93 octane.
unnecessary my a$$ i have the 3.5 I also dug this up in my owner manual this is on 9-4. "Octane rating tipsUsing unleaded gasoline with an octanerating lower than recommended can causepersistent, heavy “spark knock.” (“Sparkknock” is a metallic rapping noise.) If severe,this can lead to engine damage. If youdetect a persistent heavy spark knock evenwhen using gasoline of the stated octanerating, or if you hear steady spark knockwhile holding a steady speed on levelroads, have a NISSAN dealer correct thecondition. Failure to correct the conditionis misuse of the vehicle, for which NISSANis not responsible.Incorrect ignition timing may result in sparkknock, after-run and/or overheating, which maycause excessive fuel consumption or enginedamage. If any of the above symptoms are encountered,have your vehicle checked at aNISSAN dealer."heysteve wrote:
In the 02 manual is says half of that with a twist.......If premium is not available, put only enough regular to get you to a gas station to fill with premium.skiski329 wrote:). If unleaded premium gasolineis not available, you may use unleaded regulargasoline with an octane rating of at least 87 AKInumber (Research octane number 91), but youmay notice a decrease in performance."
