MPH »
https://forums.nicoclub.com/mph-u18179.html
Sun Jul 18, 2004 6:53 am
I'm working on an 87 Maxima that will not rev up. It acts like a bad MAF, but I've replaced it and no change. The signal voltage from the MAF to the computer remains constant and doesn't change with airflow. Adding fuel does not help, It is already running rich, but the CHT sensor is OK. It appears to have no spark advance. I've verified the valve timing and initial spark timing, voltage and ground to the MAF. The ECU is not getting 12 volts to pin 18 from the throttle switch at closed throttle. I've tried to adjust it and I can only get 7.5 volts to it. I've tried another throttle switch and it is the same. Someone has been working on this car before me and may have mis-wired the throttle switch. I cannot find a good resource on how the throttle switch gets it's power, but in the wiring schematic, it is somehow hooked up to the the fuel pump relay. I don't want to throw any more parts at this car, but I suspect either a problem in the throttle switch circuit not allowing spark advance or a bad ECU. Can anyone help me with this? Sorry for the long post.
