Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Sun May 13, 2007 4:25 pm
Well, how much oil are you putting in the engine when you do the oil change? Is it burning any oil during the oil change interval.
A lower oil pressure over time is usually a result of worn engine bearings. As the bearings wear, it creates a less restriction on the oil pump. Because of this less restriction, it will result in more flow, and less oil pressure to be developed. This could be a beginning problem to an engine that is wearing down.
