cwrench »
https://forums.nicoclub.com/cwrench-u39643.html
Sun Apr 16, 2006 6:19 am
Truck has new starter, distributor cap, plugs, HT wires, battery. Fuel pressure is on spec. When humidity is high sometimes will not start although has spark and fuel. New distributor cap seems to cure problem for a time and then (within 6 months) problem re-appears. When it won't start, if you put a timing light on #1 it appears it is not firing at the correct point although it does show spark. It has been into the local Toyota dealer (no Nissan dealer within one hour drive) and their top trouble shooter replaced the cap again to cure the problem. I'm convinced the caps are being carbon tracked over time (although I can't see physical evidence inside cap) due to ignition firing problem. I'm about to replace the ignitor which appears very rusty but at this point I'm just throwing parts at it. I need help.
