Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Wed Aug 29, 2007 5:07 am
I'd never swap out FI for a carb, but that's just me. The fans will help, but be sure your alternator is up to the task....the alternators in these things are fairly low output...like under 70amp, and fans can take up to 30 amps by themselves.
Intake and exhaust will also help. Pacesetter makes a header for your engine, I believe. Save the money on an aftermarket exhaust and just have a local muffler shop (not Midas or Meineke, but a mom/pop place) fab you up a 2.25" exhaust with a free flowing muffler of your choice.
You're not going to get huge gains no matter what you do (unless you go nuts and turbo the thing), but this stuff will help. also, on a 20 year old truck, give it a good tuneup....plugs, wires, cap, rotor, and clean the injectors by running a can of seafoam through the gas. You're also not going to get significant gains in HP with the ignition upgrades, provided your stock ignition system is in good working order.
