SK8ERSQUREL »
https://forums.nicoclub.com/sk8ersqurel-u293587.html
Fri Dec 20, 2019 9:08 am
I got the Fsm on tap, and I have used the troubleshooting process, but it leaves alot of questions too. Like i know i dont have battery voltage at all injectors at the ecu harness, yet it doesnt tell me what to check in that case exactly, just offers more testing. So I'm having a issue pinpointing where the current stops or has a break, and the ecu says it all good, I did get it to pop up codes 21 and 22, 21 is for ignition module switch I replace the Cass so that might fix that, and my fuel pump is normally unplugged because it runs on constant so that's all good. I have not been able to make it recreate those codes. But I am having my father come down today to help me look at it, he believes that the injectors are gummed up but I feel like we need to address the problem that I'm not getting power to them that I am aware of. So I'm going to redo the test as per the FSM States today, and clean my grounds and swap out my EFI relay. Do you have any other suggestions I am wholeheartedly open all I want for Christmas is my baby to run
