evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Apr 27, 2016 11:37 am
Welcome to Nico!
You must be quite young if you think the VG30DETT has limited aftermarket and low potential. Not a swap worth doing imho but plenty of 500 whp z32's on stock bottom ends prove their potential on stock internals to be greater than the VQ35's stock internals. Sure the added displacement makes it easier to hit lofty hp goals but the VG30DETT starts with 2 turbo' intercoolers and all you need to make nearly 400 whp. The VQ35 after adding a turbo kit can get about there before the stock internals start breaking.
What would I suggest, VG30ET, it's the stock z31 engine so it bolts right in in place using all OE parts, better yet, sell the n/a and start with a turbo car, if you get an 87.5-89 you'll get the CLSD, the best LSD to come in any Z car from the factory period. Add an intercooler, ecu tune, intake and exhaust and you can get about 300 whp before you run out of turbo and injectors, upgrade the fuel and turbo and you can get around 400 whp before the head bolts and gaskets give way.
Can you swap a VQ in, sure, the VQ has been swapped into earlier Z cars, it's not easy, it's not cheap but it can and has been done, it's just not the easiest or cheapest way to make power in a Z31, or Z32 or any Z that didn't come with a VQ, and for the cost fo the swap you could just go buy a 350Z, turn the key and drive.
