86 Z24i will crank but not run
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Mr_twitch
Car: 86 Nissan 720 4X4 Z24i
I have a 86 Nissan 4x4 with a Z24i and i 5 speed. I have changed fuel pump, filter, throttle body, distributor, and i just cant get the thing to run. I will crank when the starter is engaged but as soon at you let off of the key it will die. You can manually feed fuel and it will run... I'm so lost
seang
Car: Ford Fiesta ST
Fuel Pump Fuse?
dvdswan
check both of the ignition coils. exhaust tends to go bad alot.
Return to “Datsun 720”
