'86 Nissan 720 Weber Vacuum lines?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Syphious
Car: 1993 Nissan 300ZX 2+2
1986 Nissan 720 4x4 DLX
Hi guys, so ive installed a 32/36 DGEV elec. Choke carb to my 720 with the Z24 and cant find any straight up answers to what vacuum lines are necissary for the engine to run properly with correct vacuum pressure AND advance so the dist. Can still retard and up the pace of the timing depending on the rpms, and whether or not if the VVT and EGR really are ok for removal along with the rest of the emissions stuff, as the exaust vacuum from the vvt and egr could affect the timing advance working properly? This all be ok? What vac. Line needs to be plugged into the carb? Only the main vac. Advance line? And what lines need to go into the manifold itself and the thermal vacuum valve?
Diagrams that point out lines would help and be appreciated as to figuring out where things should really be going instead of hearing the mismatched things and info others have done that just work for them and theyre setup and truck and preferance. Im going to probably remove the charcoal canister as well. Emissions dont matter where i am and its extra junk cluttering the engine bay, Thanks in advance for the info! Can provide images of my engine bay if need be
frapjap
'07 Subaru Legacy
Howdy! Sounds like a fun project you're working on.
Take a peek at the link in my signature to see if there is an FSM for your year/model truck. Good luck with the work!
Return to “Datsun 720”
