86 720 z24i poor idle and acceleration
720nissan
Car: 1986 Nissan 4X4 720 ST
I have an 86 720 4X4 that does not idle well. Once below 1,000 rpm it sputters and stalls. It also surges and has hesitation until about 3000 rpm. Here is a list of what I've done. New plugs, rotor and cap. Checked ignition timing. Installed a new idle switch. Check vacuum hoses and sensors including a new 02 sensor. Computer does not show any codes and returns a 44. The motor is a fresh reman as well. Is there anything I can do to get this truck to run right? Has anyone experienced this issue before? Any help appreciated!
Modified by 720nissan at 2:07 PM 1/21/2009
rocklobster87
wow, thats a doosie. timing chain on right?
720nissan
The timing chain is correct. I'm pulling my hair out with this thing. When you start it, it runs great for about 10 seconds and then it goes to crap. I'm thinking its something to do with open/closed loop system of the eccm. The ignition timing looks right (5 degrees BTDC) for about 10 seconds and then goes to about 10 degrees ATDC with the distributor turned all of the way BTDC. I've checked and trouble shot all of the sensors (I have the factory supplement manual for the 1986 z24i electro injection) and they all are fine. I'm starting to think it's the eccm itself.
PEZi
FI or CARB?
PEZi
FI... so you may want to try new injectors and things of that sort
ride1782
Car: 1995 nissan 240sx
might want to swap out the fuel pump relay. its located on the pass by the kick panel. black rectagular box. part #28545-89900. had the same problem. would slow down at a light and it would die. cost me 61.00 i think.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
carb'd? replace all vacuum lines. The manual says to check for leaks grab some hose and use it like a stethoscope and follow the vac line listening for leaky sounds. *edit you checked them
You replace your fuel filter lately? I replaced mine and my 720 starts easier than before.
How does your valve train look?
mitch89
Car: 1989 s13 240sx
i don tknow if you fixed the problem yet but my truck was doing around the same thing. i replace the TPS and it runs so much better now, but she still idels a little rough and it seems like the truck has no balls, that might be me used to my ka24e in my 240sxmitchell
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
How's the fuel pressure? Is it steady?
