BootstrapBill »
https://forums.nicoclub.com/bootstrapbill-u216281.html
Thu Mar 07, 2013 8:48 am
My '86 720 z24 carb'd 4x4 falls flat on its face on hard accleration till it hits about 3k rpms then takes off like a rocket. I'm new to this truck, and nissan in general, (chevy man) but i need some help fellas. Ive replaced the spark plugs, both coils, wires look good, carb seems to be working fine but not 100% sure. Idles great, e- choke.works, no visible vacuum leaks, not possitive if secondary is opening up, or if acceleraterpump is working properly. Truck stumbles on light acceleratiin, and falls hard in normal to hard acceleration, but pretty consistant on around 3k rpm and up. Just picked up a carb gasket kit to rebuild the factory carb next, but any and all suggestions/advice would be helpful! Thanks in advance!
