86.5MM-1.5MM Headgasket HELP!!
Solow240sx
Car: sr20 powered 91 240sx
Ok guys i've been looking all over and what dead set on running an Apexi head gakset, but i can not find one anywhere is 86.5mm and 1.5mm thick, Does anyone no where i can get one and if not are there any other good headgaskets in this size????
Hijacker
Car: '92 240sx Convertible
'94 F-150
Cosworth
Solow240sx
Where have u found cosworth in 86.5mm??
Hijacker
'94 F-150
I see what you're getting at now.
I have yet to find a performance head gasket in 86-86.5mm bore. They usually design them around 87mm bores.
Solow240sx
Yes, i am in the middle of building my sr20 pretty strong with cp pistons, eagle rods, acl race bearings, 264 cams, springs & titanuim retainders, and all i need is a good headgasket, the motor is actually at the machine shop right now, and if i woulda known this i would bored it to 87mm, although i really dont wanna bore it that far... What should i do?? ANYONE no where i can find a good 86.5mm headgasket? Perferably apexi??
Hijacker
'94 F-150
You can run a headgasket with a slightly larger bore. I'm running an 87mm bored gasket on an 86.5mm cylinder bore with no issues.
The stock gasket doesn't come all the way to the cylinder bore edge either.
Solow240sx
Thats what the sales tech at frsport said to but that kinda, makes me feel alittle iffy, anyone else have any info??
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I think I got the 87mm x 1.5mm cosworth head gasket on my stock 86mm bore. Is that ok?
Hijacker
'94 F-150
Solow240sx wrote:Thats what the sales tech at frsport said to but that kinda, makes me feel alittle iffy, anyone else have any info??
I had the same feeling when I was putting my block together. My friend, who has been a mechanic for over 35 years, told me it would be perfectly fine.
Solow240sx
Hijacker, what kinda power are u making?? I might just have to go with an 87mm headgasket..
Hijacker
'94 F-150
stock T25 right now at 12 psi. I haven't had it on a dyno since the rebuild, so I can't tell you specifically what power it's pushing
Plus it should be upgraded to an S15 T28 and supporting fuel mods within a month.
Solow240sx
Ic, thanks for the help man!! Theres gotta be some more people on this forum that ran into this problem...
jr_ss
Car: 95' S14
No one makes an 86.5mm head gasket.. Go with the 87mm...
Solow240sx
Haha, just my luck, i can't believe no one makes a .20 over headgasket for the sr20...
Slipstream
Car: '94 Sonoma, '90 300zx n/a
I haven't finished my build yet, but I went with a GReddy 87mm x 1.8mm.
Solow240sx
Ok looks like thats what i will have to do, Thanks a bunch guys...
