Drafteddesign »
https://forums.nicoclub.com/drafteddesign-u150044.html
Fri Aug 17, 2012 1:07 pm
My buddy bought a 86.5 Hardbody with the Z engine in it after its sat in his friends backyard for roughly 3 years. We went over today to work on it to try it get it going and it wouldn't do anything. When I turned the key,the fuel pump primed itself and the relays on the fuse panel clicked, but that was it. The starter wouldn't do anything, headlights won't turn on, the interior light won't come on, no dash lights, but the wipers will work. Someone had tried swapping the computers under the seat before, but the comps had different numbers on top of them. The stock computer was numbered 40, but the one the previous guy had swapped into it was numbered 14.Are these numbers important or are they all the same? The 14 computer wouldn't even let the fuel pump prime itself and the leds inside it wouldn't light up. After removing it and hooking up the original 40 computer, the led's lit up and the fuel pump started working. On the passenger side fender well, there is a bank of relays with two called fuel pump relay and the other called main relay. We swapped those two relays to see if the main relay was the issue, but nothing changed. The fuel pump still primed itself, but the starter didn't engage , the solenoid didn't click, lights wouldn't work, etc etc etc. We checked all of the fuses in the fuse panel and they were all good.
Does this sound like something that any of you have run into? Any help you guys can give on this would be greatly appreciated
