66buickguy »
https://forums.nicoclub.com/66buickguy-u248981.html
Fri Nov 06, 2015 6:40 pm
Hey guys and gals.....I have an 86.5 Nissan hardbody 2 wheel drive 2.4 liter FI 4 cylinder 5 speed extended cab and just kind of looking for some suggestions........the truck has started sputtering really bad under acceleration and worse when engine is cold.......the more I push on the gas the worse it gets until I let up unless I let it chug for 10 seconds then it will come out of it at roughly 3,000 rpms and run fine........also sometimes it will miss at idle even when engine is at running temp........ this problem occurs occasionally when the engine is at running temperature but definitely more pronounced when cold...almost like something is choking the motor.........the truck has had a problem for a few yrs where I have to push on the gas to get the engine started after its warmed up then it pukes out a bunch of black smoke and used to run fine.......air filter also just started to get soaked with engine oil in about 2 months...........I've pulled the passenger seat to check codes and my computer has no switch to do code search....it has the green light but no code search knob or switch.......plug wires, distributor cap, plugs, rotor, fuel pump, fuel filter....all new within the past 6 months......I'm at a lose.... any suggestions appreciated
