blueline »
https://forums.nicoclub.com/blueline-u122301.html
Mon Dec 15, 2008 4:20 am
I have a '86 300zx turbo that has a couple problems. First off, its hard to start in cold weather. I check ECU codes, and found that the MAFS is bad, Cylinder head temp. sensor is bad, and the fuel temp sensor. If im lucky it would start after 10-15 cranks. (engine rotates but no fire). The other day I was messing around with it and unplugged the CHTS from the harness, and to my surprise it started right up. Secondly, when it does start, and after a proper warm up I cant hear any turbo spool, sounds like a reg. v6??? also, there's no boost till around 4,500 RPM.
Any ideas?
