86 300zx runs poorly cold
A home for 1983–1989 300ZX owners!
carnut1
Car: 1986 300zx coupe n/a 5 speed
My 86 n/a has new plugs (proper NGK's), wires, cyl head temp switch and a tested good idle air valve. All these parts were replaced to hopefully correct a cold start "no fast idle" problem. Starts right up, idles very low 400 to 600 rpm. Feather the throttle to drive 3 blocks, then it runs great the rest of the day. The idle air valve air door is wide open cold like it should be and closed in 5 min. The exhaust smells a little rich when cold as I would expect because there is no fast idle. Besides the air valve and the fuel temp switch what enables the fast idle? I have the factory service manual and have overhauled/rebuilt cars for many years. I dont understand why, with the idle valve open, there is no fast idle. Timing is at 20 degrees, engine temp normal (new Nissan thermostat) 133k miles. What am I overlooking. Last winter with air temp in the 50's I had fast idle, in summer with outside temp at 60 to 70 degrees in the morning, no fast idle?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
doesn't the n/a have a seperate FICV?
Return to “300ZX (Z31) Forum”
