86 300zx 2+2 i need help ASAP
A home for 1983–1989 300ZX owners!
86300zx
Car: 1986 300zx 2+2
ive bought an 86 300zx a few months ago for 1100 and drove it home the owner told me it only needed a battery and tires so i did what any z owner dose and took care of my new found love... when i got it home i started to work on her bc i very quickly found out it wasnt fast enough for me so i did took of the ac and cruse control and Carol canastor put an electric fan on it then the car sat for a few months bc i didnt want to drive it in the snow... ok now that you have the background on the car here is my problem...
after letting it sit i went to fire it up only to find out that the battery was bad so i put a new battery in it and my friend was helping my at the time he put the battery in backwards .. i didnt know it at the time but i double checked before i started it i switched it to how it need to be now the car will not start and stay running at all its not getting fuel to the motor so i assume my relay switch is bad or the fuel pump is bad i cant find the fuel pump.. i removed the back seats and carpet to find it but its not there and i cant find the fuel relay switch to replace it ive been told so many things on where its at and still cant find it i know its a little blue box... but thats about it..
thanks for the time to read this
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the fuel pump relay is located in the "B" post IIRC, have you checked allt he fuses?
86300zx
Car: 1986 300zx 2+2
my fuse box dosnt have a cover on it so i dont know what fuse goes to because alot are missing and i havnt pulled any yet but i will look thanks how many fuse boxes dose my z have? and what kind of deletes can i do that will give me more power? and what are some simple mods that will help my car? and what is the best way to do the fuel pump
evildky
06 Nissan 350Z GT
If you browse xenon and az zbums sites you might find a fuse panel diagram, I know xenon has the fsm in pdf form for download. All of your fuses should be good, just check them all. Fuel pump on the 2 seater requires the tank to be dropped, not sure ont he 2+2. As for making the car faster, well it helps to start wiht the lighter 2 seater, remove everything not needed to stop, go or turn. Beyond that the n/a just doesn't have a lot of potential, the turbo swap is pretty simple and opens up almost endless power potential.
86300zx
Car: 1986 300zx 2+2
how hard would it be and what would i need to be to do the turbo swap?. and i got the car running this morning it runs awsome
evildky
06 Nissan 350Z GT
again, read through xenon and az zbums sites the swap is covered in detail. Front crossmember, driivers exhaust manifold, turbo, downpipe, oil lines, oil pan, ecu and injectors, not difficult for me, for some it might be.
86300zx
Car: 1986 300zx 2+2
can you send me a link
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Return to “300ZX (Z31) Forum”
