I'm working on an 86 300z non turbo, man. trans. It stalls out at 2150 rpm, and picks back up around 1800 rpm. I've tried everything, including ecm replacement, maf, tps, (vehicle did have tps code w/ original ecm), crank angle sensor/ pickup, dropped the exhaust to see if the cat was clogged creating back pressure. I'm told there's a rev limiter involved with the maf signal that would cause this problem, but checking the voltages to the ecm from the maf reads 2.4-3.6 dcv. Supposedly within specs. Fuel pressure was below specs, so we replaced it also, along with pressure regulator....no help.
Anybody ever run across this problem? Any one familiar with the rev limiter circuitry? Any help would be deeply appreciated, and yes, we have considered c4.
