I'm working on an 86 300z non turbo with a manual trans. It stalls at 2150 rpm, no spark/ injector pulse. It picks right back up as soon as it decreases rpm's (roughly 1600-1800 rpm's). I've replaced the MAF, cleaned the connectors, checked signal to ecm (2.4-3.2 volts dcv @ ecm), replaced coil, power transistor, ecm, fuel pump was below specs/ replaced, new f. filter, ecm, crank angle sensor, pickup, F. pressure regulator, practically everything that could be related, including dropping the exhaust thinking a clogged cat could be creating enough back pressure to activate the rev limiter(?)....no change.
Speaking of the rev limiter, is anybody familiar with this circuit? What wires does it use (part of the Maf circuit?), and how does it work?
Any suggestions, advice, knowledge would be very much appreciated. Yes, we have considered C4 as an option.....
