'86 200SX gauge cluster questions
McTimson
Hi everyone, I just joined because I picked up a digital gauge cluster from an '86 200SX from a junkyard, and need some info on it...
I was stupid, and didn't get the wiring harness from it...I might go back tomorrow and take it out, but does anyone have a pinout diagram for it or anything? Before I even try getting it into my car, I'd like to see if it even powers up, are there any 2 pins I can just supply 12v to to make sure everything works? (Well, light up, anyway)
Also, is there a seperate power supply type thing for this gauge cluster? If so, where is it located in the car so I can take it out?
Thanks!
float_6969
can we get a little more info? Is this going into another 200sx? Is your current cluster an analouge? You might see if you can get your hadns on a Factory Service Manual, or maybe even a Haynes or Chiltons.
KaZ (VaBch)
Also, check out http://www.club-s12.org. You'll get a lot more info on the S12s there... this forum is better for S13/S14s...
