Semi-perfectly put in the fact that it is a boost and load friendly little engine. However, it really is designed to rev pretty good and high, but the point of nissan designing it this way was possibly so that you can have a little fun after the T2crap turbocharger runs out of puff. It truly is a revver, but it can use a little help to do it effectively (ie solid lifters, serious cams, etc). One must remember, the head is the hottest part of this engine that allows you to rev the crap out of this motor, but realistically float is right in the fact that 8000rpm is all you guys really need.blownhemi wrote:Maybe there should be a sticky reminding people that this engine is not built for revs, not in the least. What it lacks in revs in comparison to other engines, though, it makes up for in boost-ability.
it woudn't hurt any. Those stock valve springs wear-out after about 100,000 miles or so>niswiz wrote:i was checking because i was trying to decide if to purchase some aftermarket valve springs to complete the engine. so the next question is do i need aftermarket springs for 7500 rpm at 8.8mm lift? springs are rated at 11mm lift.
4G-63Really, the 4AG is the only thing (IMHO) from that era that even comes close, and as dash has pointed out, the 4AG has it's flaws as well (When is the last time you ever heard of a CA18 splitting a cylinder?)
FJ20.............D_Stirls wrote:4G-63Really, the 4AG is the only thing (IMHO) from that era that even comes close, and as dash has pointed out, the 4AG has it's flaws as well (When is the last time you ever heard of a CA18 splitting a cylinder?)
Cosworth YB seriesNUTCSE wrote:
FJ20.............
how can 9500rpm make sense to you, but 10,500 doesn't? Neither will be quicker than a 8000rpm combo. That's "nice" ?revving isnt over rated, the ability to broaden your rev band and scream to the stratosphere is nice. 10.5k, now thats pointless
example; two valve 1.8L SOHC, full weight, factory motor, factory transmission.... goes 9.1sec, no spray. He needs revs??Smaller displacement engine have to get moving and build their rotaional energy to make their power (B18C5 8.?k rev limit). They dont have the benefit like a chevrolet 454 does
no magical cam & turbo combo gonna make gobs of torque at 4k and hold it to 9.5. That's a fantasy.so why not go to 9.5 and have 5.5k rpm worth of useable power
FJ head next to CAfloat_6969 wrote:The 4G is a good motor too, but the rest of drivetrain and the vehicle it was used in, weren't great IMHO. The FJ is older technology than the CA or 4G, so I wasn't considering it. Although given the 3, the FJ is better than both. If it were an option, The CA would be gone and I'd have an FJ24 in the S14.
exactly..... like most "monster" street CA18s haveSave bearings, turn up boost
from memory..... my 4-port ca18 head look like my 1st gen dsm twin4G63 looks like an inbred cousin of the FJ
