85 nissan pickup vacuum lines
babyethan1
Car: 1985 nissan pickup
I recently re did the head gasket on the lil z24 it has the stock carb. I was stumped on all the vac lines so i got reading and was told that I can remove all but the dist advance hose.. So that is the only vac line left, I need to know where exactly it plugs to the carb.. HELP ANYONE :gotme
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
You will also need your power brake vac hose hooked up. Mid 80's Nissans were vacuum hose nitemares so best of luck to you.
longtooth
Car: 89 d21 HB
I would ask the person that gave you that information.
