Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Sep 22, 2008 4:15 am
Just FYI - a 1985 truck is still the old 720 body style, not a hardbody.
If you can get the truck to idle, either by cranking up the idle screw, there's a few things you can do to check to see what the issue is - get a can of carb cleaner and start spraying around all the vacuum fittings (not directly into the carb). Listen for RPM changes when you do this. If you encounter big changes, you're finding vacuum leaks, and that's a leading cause of foul running carb'd motors.
Also, chances are it could use all the normal tuneup stuff...Cap, rotor, plugs, wires, etc. if you can get it to run and it's not belching blue smoke indicating oil burning, that price probably isn't too bad for the truck if you just need a beater.
