Having an issue and looking for suggestions. My '85 model with automatic transmission suddenly won't shift out of 1st. I can place it in first, then shift it to second manually and it shifts fine, but won't shift out of first when in drive. I have the service manual, and have checked the fluid. Also checked the vacuum diaphragm and kick down solenoid. Anyone had this issue, and if so can you weigh in with the most likely culprits?
Thanks in advance for any ideas or suggestions!
Josh
