85 300zx Turbo blinkers don't work!
A home for 1983–1989 300ZX owners!
85zx
Car: 1985 300zx Turbo
The blinkers won't work on my 300zx. The hazards will work on the right side and sometimes on both. Any ideas? I think it is the flasher but I have no idea where it is.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if the flasher goes then the hazards won't work either, I have a look at the stalk and the chassis grounds
85zx
I will check the ground but where should I look? any ideas?
evildky
06 Nissan 350Z GT
there si one ground in the rear in the back passanger corner (IIRC) just pull the panles and trim out and follow the wire harness, up front I can'tremember which side the ground is on, but I believe it's on a rame rail (IIRC) sorry but so many car I have a ahrd time remembering the details on each
the easiest thing to do is to locate the ground wire leading to the non functioning light and run a good new ground to it, if this fixes the problem then youfound the problem, if it blows a fuse you hooked to the positive ;)
has anythign changed lately? a lot of times people put in aftermarket stereo's and groudn to the illumination circuit causing all sorts of drama
85zx
My car has the factory stereo installed and I did find something new last night while I was working on it. I put the key into the ignition and turn it to "on" and the dome light, door lights and stereo clock do not come on., but if I turn the antenna switch on and the stereo on then the lights work. If I turn any of the two off the lights go out! Also when the stereo is on and the antenna is on the blinkers still don't work. I looked in the FSM and there are 2 relays, one for the blinkers and one for the hazards. I am going to dig into it more in a couple of days. First I have to put a new water pump and new hoses in it first. Thank you for your help!
Cory
85zx
Ok here is the update. So far I have replaced the water pump, belts, coolant hoses, rad cap, dist cap, rotor, fuel pump, fuel filter, and some vaccume lines.
And the blinkers now work. It turned out that the switch just needed to be used! Now all I have to do Is figure out what is wrong with the interior lights...
85zx
As it turns out the problem was that a fuse was missing from the fuse block.... Thanks for all of the replies!
Return to “300ZX (Z31) Forum”
