alan1970 »
https://forums.nicoclub.com/alan1970-u48711.html
Thu Oct 12, 2006 6:47 am
i just bought the car with the heater core busted and it was bypassed. runs fine like that but no heat. so i decided to replace it, got that done and hooked up the hoses and the car idles fine but when i give it gas it starts jumping around. passed 2200 rpms it drops back to 8000 rpms and back. acts like you are reving the engine but holding the pedal still as if you were trying to drive. then found out that the water c*** was missing. gat one and put it on. still did the same thing. went back to the bypass method runs fine. i found 2 free vaccum hoses, a white one and a blue one, no clue where they go. i put an advanced auto parts replacement heater core in it. the qestion is, is there anything that might still be missing from the heater system that could cause this problem and where do these vaccum hases go?
