85 300z wont start
A home for 1983–1989 300ZX owners!
snowsZ
Car: 1985 300z
I LEFT THE T TOPS OUT AND CAR GOT SOAKED I REPLACED FUEL PUMP BUT IT STILL WONT CRANK. I HAVE POWER ON ONE WIRE GOING TO THE FUEL PUMP BUT IT IS NOT PUMPING ANY FUEL ANY SUGGESTIONS
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
first of all welcome to NICO
second, lower case please, the caps thing is considered rude
third, the Z31 uses an intank pump if I recall correctly, and it depende on the ecu sending the signal to the fuel pump relay to turn the power on at the pump so that would imply that you have a faulty ground? or a dead pump? are you sure your measuring voltage at the right point? fuel pump and sender all in one assy aren't they?
also you said that it isn't pumping any fuel, do you have a fuel line off? or a feul pressure gauge in line? I'd like to know how you determined that it's not pumping sometimes we assume it's one problem when it's really another
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
The Z31 uses a ground signal to control the pump. With the ignition on you will have + voltage but check the - wire to the pump. It is controlled by the fuel pump relay in the pass quater panel behind the pass seat. The connector for the pump is in the back hatch on the floor beside the spare tire well. The Z31 has a pump controller so it pulses when ignition is on for about 3 to 5 seconds and doesnot inguage again unless the car is turning over or running.
snowsZ
Car: 1985 300z
i had a guy look at my z today he jumped a ground wire to a screw in the trunk and the pump started checked the ecu under kick panel on pass side and the lights in the display window are not lit up would that mean that the ecu is not working and sorry about the caps thing
evildky
06 Nissan 350Z GT
no lights means no codes, sounds like you got it running but havn't found the real cause, if it's a switched ground it could still wel be a bad relay, should be pretty easy to check
NSR240sxe
Car: '97 Kouki S14, '98 Sentra SE
Welcome to NICO!! Good luck getting your car running right.
winez31
Car: 1993 s13 ka24de
the fuel pump relay is on the passanger side pillar. replace it thats probably your problem. o yeah welcome to nico
snowsZ
Car: 1985 300z
question onthe ecu when u turn the key on are the red and green lights supposed to come on and then when u turn the screw on the ecu clockwise it flashes the code i have heard two differnt things
winez31
i couldnt tell you when i replaced mine the whole thing was shot. go to az-zbums site or z31.com or red z31 one of those shows how to read the codes. i wouls try az-zbums site first.
snowsZ
Car: 1985 300z
well i am lost please help i found another ecu today plugged it in and nothing the lights dont come on or anything the car will turn over but that is it i changed the fuel pump relay and nothing happened any more suggestions
DustinZ
You have three fusible links to the ecu that need to be checked if you are not getting power and also you need to check your grounds. If you do not have any electrical back ground it will be hard for anyone to tell you how to fix it. I would first check the power to the ecu, second check fusible links, third check grounds. You said your lights don't come on? Do you mean dash lights? You need to be really specific with all the information you can give. I wish you the best in fixing your z.
winez31
check timing my friend "retimed my car" and it wouldnt start then when i timed it it started fine. has the timing belt ever been replaced?
Return to “300ZX (Z31) Forum”
