Pitts »
https://forums.nicoclub.com/pitts-u231537.html
Thu Jun 05, 2014 8:39 am
After reading forums alll night last night (till about 5am) and doing some testing here is what I've come up with.
Diagnostic check: Codes 31 and 23 (AC isn't installed, so that explains code 31)
TPS: I can either get millivolts or battery voltage based off of adjustment. When it's adjusted to millivolts for idle, it does read at battery voltage when the throttle body is opened up. One of the wires reads millivolts for conductivity to the throttle body whereas the other says 9.4 volts. Which the FSM says to replace the TPS/TVS. Also read that I can unplug the TPS and if she runs better and I can apply throttle, it's a good sign that the TPS is out. I tried that with no change.
CAS: Tested the connector for the harness as the FSM depicts, I had good voltage from pin 1 (positive) but bad resistance from pin 4 (ground). The FSM says to replace the harness. While the ECU didn't give me this code, I still tested to rule it out.
Fuel Pressure: I've been eying the pressure every time I'm under the hood. It's had between 30-36 psi (depending on load when it ran yesterday).
Coil, plugs, cap, and rotor: Visual inspection, as well as tested and all were great.
Vacuum lines: I've recently replaced all the lines that are used (EGR, FPR, cruise control) so I know they are good.
Ignition timing: at 15 degrees.
Timing: belt and all gears line up perfectly.
For the past couple months she liked to act up when cruising (typical TPS/TVS issue). However, 2 days ago, she started idling rough and seemed to lack a little power. Then that night as I went out to pick up some pizza, I only made it about a mile downhill before she quit on me. Didn't have much to do a diagnosis there, so I did a couple small things such as pop the line off the fuel filter (which was replaced 3-4 months ago) and I barely had any fuel in the line. Which made me think of my fuel pump. Did the standard (for me anyways) sit and wait, then drive as far as possible (being careful to not stress the pump too much). So, the following day after I adjusted the TPS some, it ran great for about an hour and a half. Since then. I cannot get her to stay idling for long and if I so much as open the throttle body a millimeter, she stalls instantly. Tried running with the TPS/TVS disconnected and no change. It could be the fuel, I'll be running over to the gas station (it's not a long trip, maybe 120 feet to the pumps from my house) and trying some new fuel. While I highly doubt it will solve anything, sh*ts and giggles right? Grab a snack while I'm at it.
When I could drive it the other day and it started to act up, it would bog down horribly. For example, I'd be in second gear at 3200 rpm and it would basically act like I took my foot off the throttle and was using the gear to slow me down. Yesterday I could get her to idle while being towed home so I could apply the brakes. Today, I'm lucky if she idles for 10 seconds.
Anything else I should test?? I need my car as I do work tonight in 12 hours. Thanks.
