BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Fri Jul 22, 2016 11:39 am
I wouldn't try to go up as big as 18", since the car came with 16". There are great tire choices in the 16" size to choose from to update the ride, but if you want to do the wheels tire rack probably has something that would fit. I have a NA sot he 4 bolt wheels held me to 16" Enkei's that are great, ride super solid and balance like OEM. You can switch over to super sticky tires too for pretty cheap and it will transform the handling. I put 225 50 16 Bridgestone Potenza RE-71R with the Enkei Classic Comp Gunmetal ($143 per wheel) with the wheels pre-mounted and balanced for $1200.
The mustang route seems to work for alot of people, but there is nothing like a good brand new set of wheels and tires for an older car like ours.
