84 z31 turbo
A home for 1983–1989 300ZX owners!
84turbo
Car: 1984 300zx Turbo
My 84 300zx turbo will run fine at idle, but when I drive it, in about a mile or 2 it will begin to miss and eventually die. Let is sit for a few minutes, it will start back up and run again for a mile or so, then die. I can let it idle for an hour with no issues, but when I drive it, it acts like it's running out of gas. Has new fuel pump, injectors, filter. Pressure regulator, allow ignition parts.
Anyone have any ideas??
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
My first suspect would be the fuel pump, then maybe the fuel filter since you say you already replaced them the Ignitor and or Coil would be next on the list, also the distributor itself. first thing is to check the ecu for codes. if there are no codes present when it dies and will not restart, test for spark.
Return to “300ZX (Z31) Forum”
