marbuf »
https://forums.nicoclub.com/marbuf-u246676.html
Thu Jan 15, 2015 7:35 pm
Truck has around 150k miles. It started cutting out on me a few months ago around 40 mph or higher. The idle was acting strange, started fine but after a few minutes... idle goes crazy and truck dies. Hard to start after that but, once started it'll idle again and die again (unless driving and then just seems to cut out).
First thought it was the fuel pump (one of those generic pumps) and replaced with another and new filter. Still acted up and cutting out. Later found the accelerator pump was leaking by gas. Changed out but, still seems to be cutting out
around 40 mph or higher, also seems to not have any power. Idle and die issue has stopped with the change of the acc. pump.
Keep hearing a clicking noise from under the dash. Know about the relay but, doesn't seem to cause the truck to run
better or worse when it clicks. Seems to do after hitting a bump or going over railroad tracks.
Never rebuilt the carb., replaced head gasket twice. That's my story, owned the truck for 30 years and only drive to work about 7 miles each day to a chemical plant. Keep thinking about getting another vehicle but, can't. It's like a kid to me and has sentimental value and will probably keep until it's a pile of rust.
Thanks for any ideas.
