mueler »
https://forums.nicoclub.com/mueler-u259920.html
Thu Feb 25, 2016 12:01 pm
1984 Nissan Datsun 720 King cab 4x4
I posted on here several weeks ago and got helpful suggestions. I'm reposting, because the issue (still unresolved) has changed slightly.
-There seems to be two types of stalling.
Type 1: In the last two weeks I've stalled 5 times. These 5 times have all been in parking lots and after the truck has previously run at least 15 min. I start to take my foot off the clutch (stopsign, reversing, etc) and the truck stalls. When I turn the key, it goes tttttt and either no Vroom, or the vroom chokes out after 2 sec. Continued tries = definitely no Vroom. After 20 minutes to an hour it will start as normal. WHAT's GOING ON! ?
Type 2: (happened intermittently for the last year but hasn't happened in the last 2 weeks) While driving, the gas pedal stops engaging, Then the engine then cuts out. Truck coasts to stop and will restart within a couple minutes. Might (or might not) keep stalling. Sometimes you can put it in 2nd gear and buy enough time for the gas pedal to reengage.
Recent work done: new fuel filter, new alternator, plugs and wires, rotor and rotorcap, battery (1 yr), battery terminals
I appreciate the suggestions. Thanks in advance for your help.
