I have a 84 720 4x4 and I've got the motor out and i'm going to change some seals while I have it out. I was looking at the repair manual and it says that you have to have special tools to do the job like a rear main cap puller and some other tool. I have some questions:
1. Can you change the seal without haveing to get some special tool and if so how?
2. While I have it out i'm changeing the oil pump, front seal and gaskets and oil pan gasket because the engine came out of a 2wd truck and the oil pan is different. Is there anything that I should change out while i've got the motor out?
