mueler »
https://forums.nicoclub.com/mueler-u259920.html
Thu Feb 25, 2016 11:25 am
Thanks for your suggestions. We put in a new fuel filter, (and alternator because the alternator went out). It is still stalling, and now the stalling has changed: In the last two weeks I've stalled 5 times. These 5 times have all been in parking lots and after the truck has previously run at least 15 min. I start to take my foot off the clutch (stopsign, reversing, etc) and the truck stalls. When I turn the key, it goes tttttt and either no Vroom, or the vroom chokes out after 2 sec. Continued tries = definitely no Vroom. After 20 minutes to an hour it will start as normal. WHAT's GOING ON! ?
Past type (happened intermittently for the last year but hasn't happened in the last 2 weeks) While driving, the gas pedal stops engaging, Then the engine then cuts out. Truck coasts to stop and will restart within a couple minutes. Might (or might not) keep stalling. Sometimes you can put it in 2nd gear and buy enough time for the gas pedal to reengage.
Recent work done: new fuel filter, new alternator, plugs and wires, rotor and rotorcap, battery (1 yr), battery terminals
