84 720 4x4 tranny- will z transmission work?
A home for 1983–1989 300ZX owners!
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
ive got a 84 720 king cab with a blown transmission. my local junk yard has a 240z and a 280z sitting there. i was wondering if those trannys would bolt to the truck, because it has the 2.4 z motor. any input will be appreciated
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
i take that back. ones a 260z and the other is a 280zx. anyone know if they would work?
Mr1der
the L and Z series blocks are very similar...I'm not for sure if it'll bolt up...but I'd atleast count on needing work done to the driveshaft.
shouldn't be too hard to find a 720 with a 5 speed if you've got a little time though.
datsundude
Car: Every Nissan Imagineable
The z-24 transmission has a different bell housing and will not work for this. I have tried it, and it physically will not bolt.
MrZed
Car: Nissan R30 Skyline
The Z24 is the same block design as a L26 so it accepts the same bellhousing, but the problem is the tail end. The z transmission may have a long tail end which is too long to fit between the engine and the transfer box. Measure the length of the trannys, and if they're the same length, then you're in luck
Mr Lee5353
Car: 89 hatch
06.5 scion xb
72 datsun 510 wagon
thanks for your help guys
Return to “300ZX (Z31) Forum”
