84 300zx wont go over 30 mph
A home for 1983–1989 300ZX owners!
Cregerzone
Car: 84 Datsun 300zx
Just bought an 84 Datsun 300zx, the only issue is it wont go over 30mph. I dont believe the transmission needs to be replaced but I'm at a lost.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Welcome to NICO. I moved your thread to the correct area.
A speed related issue is an unusual one. First fo all auto, or manual? does gear selection allow you to run higher rpm but still limiting the car speed?
akaNYr
Car: 1986 300ZX 2+2 NA
I just bought an 86 300ZX 2+2 NA, auto transmission and it wont go into 3rd gear most of the time. Top speed it'll do is about 28-30mph. The transmission fluid is BLACK but it dont smell burnt as far as i can tell. I'm going to change the fluid and clean out the transmission filter by spraying with brake fluid. I'll probably repeat this about 3 times after every 100 miles then it should be clean. While I'm under the car draining the fluid I'll check the transmission vacuum module. If transmission fluid is in the hose or dripping from the module then the module is bad. Some Z's use the vacuum module to help determine when to shift. Lastly, If that don't do it then I'm going to check the kickdown cable to see if it needs adjustment. I've been researching for a few days and that's all the info on possible causes it may be.....without getting it rebuilt. Good luck, I hope one of these fixes it for you. :dblthumb:
Return to “300ZX (Z31) Forum”
