84 300zx shuts down HELP
A home for 1983–1989 300ZX owners!
barouk
Car: 1984 300zxtt
i recently became the owner of a 1984 300zx, that sat for months, the first couple of weeks it ran fine, now it may have a hard time starting and will shut down and may instantly come alive again, sometimes not. does anyone have any ideas. thanks
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Welcome to NICO!
I'm sorry to say I don't have much of an answer, I'd check all the electrical connections, including the batter cables, and the AFM, being in Nashville, if you can't track it down on your own, go to Crawford Z Car Service, they know Z's of all generations
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
When you have problems starting the starter does not turn at all? and is there low voltage when the car dies (meaning light go dim or go off)? If so check the ground wire that goes from Batt to chassis to trans, starter. On the Z31's this wire loves to go bad. If you have full voltage and the car cuts that is a different problem. Let me know and I can help you out.
DustinZ
SRkazem
Car: 84' 300zx
hay I had almost the same problem.... but mine did not start at all. here are some places I looked at, fuel filter, fuel cap to see if maintaning presure,distubitor cap, ignition coil,vaccume lines, rotor, fuel relay, and then the ECU. well after going through all that and replacing half, i thought what could be the problem I've replaced every thing that it needs to run but no result than I had only one option the ecu.... well I went ahead and found an 86 ecu for cheap and took my old one out and swaped it. The car started right up after a few craks, but ever since then I have never had a problem. have fun and good luck on getting her to run.
barouk
Car: 1984 300zxtt
thanks for the suggestions, but what is the ecu. i am new to z cars, my other car is a diesel. thanks barouk
evildky
06 Nissan 350Z GT
barouk wrote:thanks for the suggestions, but what is the ecu. i am new to z cars, my other car is a diesel. thanks barouk
lol,ECU= Engine Control Unitaka: computer, ECM (Engine Control Module)
it's located on the passanger side, I can't remember on the Z31, it's either under the panel under the carpet in the foot well or behind the kickpanle, i honesly just can't remember at the moment
SRkazem
Car: 84' 300zx
LOL... it's near the passinger side, next to the door, under the glove compartment to the side remove the panel. you'll find out alot about the ZX once you start digging in to it. let me know when she's running agian.
evildky
06 Nissan 350Z GT
aka kickpanel
barouk
Car: 1984 300zxtt
thanks for your suggestions; i replaced the fule filter and that fixed the problem. Some of the gas that came out was very dark, the car did sit for several months prior to getting it; i guess there was junk in the gas tank that surfaced once it was driven again. thankyou barouk
Return to “300ZX (Z31) Forum”
