smokerz »
https://forums.nicoclub.com/smokerz-u15607.html
Mon Apr 19, 2004 8:20 pm
Just purchased this car, prior owner had started taking the engine apart, said it needed a head gasket, didn't get too far on dissassembly(definitely not a mechanic). Reassembled & cleaned up ignition. Fire up engine to find Clack clack clack coming from the front right cylinder head. Car has been sitting for 2 years. Engine bogs when accelerator pressed. Appreciate any advice on where to start looking. could a valve train component be frozen up due to sitting? Also noted a connector with nothing plugged in at the front of the passenger side cylinder head just in front of the distributor harness? Is this for a detonation sensor? Have looked every where & not found the other side of this connector? Ideas?
Appreciate any suggestions you might have.
