83 720 rear end
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
CT720RAT
Car: 1983 Nissan 720 2wd King Cab
i blew my rear (early 83 720 5 spd 4cyl 2wd), and bought a rear from a d21 (86.5 2wd 4cyl 5spd), they look almost identical, except for the spring perches, instead of cutting and welding, can i just drop the new gears in the old housing? they look the same. just want to get some other input before i go wasting time on something that may not work, thanks!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I am going to bounce this to the Datsun truck section.
CT720RAT
thanks, probably a good idea. Im about to tear them apart and see whats in side anyways, ill be back with an update in case anyone wants to know if it works. i think theres a good chance that it will.
CT720RAT
it works. everything is exactly the same. just had to swap over the pinion flange. i should be back on the road by the end of the week. :cool:
Return to “Datsun 720”
