evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Nov 27, 2009 9:12 am
the L28ET swap is a cheap and easy way to get around 260 whp, thats north of 300 at the crank, but the cost goes up exponentially to excede 260 whp, to get up to 260 whp you need free flowint intake, exhaust, intercooler, boost controler and a pipe plug, to get north of there you need larger fuel injectors, bigger turbo, upgraded engine managment, head studs, MLS headgasket and forged pistons to be safe
you said "just do a swap" you didn't say swap whay, SBC? SBF? RB, VG? ther all come with their own challanges, the RB25 for example requires the rb +trans, custom mounts, custome intake and exhaust piping, intercooler, harness, maf, ecu and to get the hp you want will also require ecu remap, larger injectors and bigger tubo, it's a higher initial investment of time and effort, but gets you more hp to start but after speiding 3k on the basic sap you are still only going to get around 300 whp, to get more the turbo and injectors need to be upsized and th eecu remapped to allow for the added fuel managment so in the end it will cost more than the L28ET
ultimatesly, build what you are most confirtable with, some gues are comfortable with pushrod V8's and carbs, and they would have a much harder time trying to build an overhead cam turbo's fuel injected engine, me I like overhaead cams, turbo's and injection
