need2fix1000 »
https://forums.nicoclub.com/need2fix1000-u160367.html
Fri May 07, 2010 6:34 am
Hey all, just bought an 83 280zx na 5 speed. It's a fun little car, but that thundering 145hp needs some help. I've been thinking about it, and I can't seem to make up my mind as to how to go about building power.
At first, I was considering swapping in a VH45, until I found out that my spare transmission isn't the 83 turbo t5, but the 80-82 turbo nissan/datsun number, so I would have to source a new transmission as well.
I have: P90 head, turbo intake and exh manis, injectors, balance rails, valve cover (who knew?) rear diff, cv's, and driveshaft.
Head is cam-less, so, that's a new set of rockers, if I can find a cam for it, but with a port and polish, valve job, and good bumpstick, the top end should be taken care of.
First question: I know with a 2mm head gasket, the flat tops should be making roughly 9.2:1 compression. Good for off-boost response, but how much power can the stock bottom n/a rotating assembly hold? Assuming no knock and good AFR's.
Second question: 3.1 stroker kit, does anyone still do this? You can homebrew the stroker set with mixing and matching of parts, but nothing from the list looks like it would be done cheaply, as all are stock parts...(L24 rods with KA24 pistons, etc...)
Third question: How much boost (I know it's relative, but it gives a good ballpark on cfm) can one of these blocks take? Stock head bolts? Head Studs? O-ring necessary?
Fourth question: Wow, 14's are NOT in style anymore... anyone have some good ideas on rims/tires/brakes?
Thank you for letting me glean the vast amounts of knowledge you guys have!
