jayceng »
https://forums.nicoclub.com/jayceng-u223009.html
Wed Jul 31, 2013 10:57 am
Sorry for the long post just want to give you guys as much detail as possible to help me fix my problem.
I just bought a 1982 datsun 720 and its my first carbureted car. When I bought the car and drove it for a couple days it ran fine. I let the car sit for a day.
First day with problem
The next day I tried to start it and the battery was drained. So I jumped it and let it warm up then tried to drive to work. As I was driving I went down hill and saw my gas gauge go from almost half tank to empty. I thought it would go back up like it would usually do. So I kept driving then it started to sputter so I went to a gas station and out gas. The car wouldn't turn on again so I had to jump it, we let it charge and sit there for a while. Tried to drive it home and it would sputter and almost die out. So I parked it and took the battery to a local auto part store to charge it. They said it was still good. I put it back in my truck and drove home. I took out the alternator and had it tested and it was fine. I later found out that the cable connected to the battery and alternator wire was loose. Turned the car on and it was fine. But them the idle was too low so it started stalling without pressing on the gas. I adjusted the throttle cable to 1500 so it wouldn't die out.
Day 2 of problems
Thought I fixed the problem I started my car for work and it idles way too low and have to press on the gas pedal to keep it on, drove to work and I adjusted the cable again, and carburetor cleaned spray.after work the idle was fine.
Day3 same problem. I warm up the car 30 minutes with my foot on pedal, still stall if I release the gas pedal. While driving to work the idle slowly goes back to 1100-1400 but when I step on the gas hard and put on neutral the idle will drop fast and it would stall, sometimes it'll catch it's self before it stalls,
My question is why is my idle so low even if I mess with the cable and why does it take so long to warm up, also when I drive home from work my car works fine, morning The outside temp is about 55-60 and after work like 70 degrees, and also I notice today that my temp gauge is not working anymore and it use to before all this happened.
